Can anyone help to tell what kind of burned IC. Is it worth it to replace the burnt ic? Or just wasting time on something that isn’t sure? A little story about what happened, when recharging, suddenly the red led indicator light stopped flashing and suddenly there was a smell of something burning. When opened, you can see that there are ic components that have been burnt. Because it was burnt, the code can’t be seen anymore.
Isn’t there anyone who can help? Is Chuwi unable to give an opinion or tell the code from the IC?
#ask-a-question #chuwi
It is a step-up converter for 5v output. Just remove it, the tablet will work fine.
