I also found this on this forum. [Official Version] Chuwi HiBox Android, Windows, Bios Download
Depend the situation
Multiple possibility i don’t know which is the best way on your case
- try to connect an external monitor. If it work you can uninstall the wrong video driver and make the screen work again for next procedure.
If it doesn’t work but keyboard work when windows is started. You can try to flash the bios with the bios flashtool without monitor. There are some video of users doing that on youtube.
It’s a tool using commandline
If keyboard and screen not working.
2 last possibility
You can try
Use a tool directly on the chip but you need to open the tablet
Or
Courcircuit 2 pin on the chip, generally a winbound chip.
The pin number depend the model
About procedure and good bios version i suggest to contact the chuwi manager directly
https://forum.chuwi.com/u/management/summary
Or to contact them on their mail
service@chuwi.com
Their are reactive on the mail
thank you very much for your help But how do I connect an external monitor because the tablet does not have HDMI outputs. or should i use micro usb to hdmi converter
Yes with micro usb to hdmi converter. Supposed to work.
Hi NikRem32
I have the same Tablet with Win10-22H2 latest version and everything works ok. I see that the cable is not compliant, it was created by you and the connections are certainly wrong.
I advise you to buy the following cables that work perfectly:
- Rampow Type C to USB 3.0 Adapter [OTG - 2pcs] Type C to USB A Cable, SuperSpeed 5 Gbps, for Samsung S9/S8/Note 8,Huawei P9, Xiaomi Mi A1/Mi 5, MacBo
https://www.amazon.it/gp/product/B07J5CDJ9Z/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
OR
- “USB-C to HDMI Hub Adapter, Arktek 4-in-1 USB Type C (Thunderbolt 3) to HDMI 4K/Dual USB 3.0/USB-C charging slot converter for Apple MacBook (20”
https://www.amazon.it/gp/product/B07BZG5CCJ/ref=ppx_yo_dt_b_asin_title_o00_s01?ie=UTF8&psc=1
Play it safe!.
Greetings
Sabino1943
Thanks for the Help Sabino1943. I have a Chuwi Hi8 tablet not a Pro version, Accordingly, the tablet only has a Micro USB Connector.
thank you so much for your help Fred009. Unfortunately not the keyboard nor the monitor does not work. It seems to me that the tablet has some kind of marriage.
2 last possibility
You can try
Or
The pin number depend the model ----------------------------------------you can about it to tell in more detail
Okay guys, I’ve already suffered with this tablet, I’ll just sell it further for details and that’s it. Thanks again to those who helped me, maybe people who understand will be able to find a solution on this forum.
Hi NikRem32
Okay. For the Chuwi Hi8 (no Pro), having the Micro USB, the following were fine:
1)-Micro USB Splitter Cable OTG Power Enhancer USB 2.0 A Female to Micro USB Male and Micro 5 Pin Female Adapter Host Charger Converter
https://www.amazon.it/gp/product/B072Z9QHYR/ref=ppx_yo_dt_b_asin_title_o09_s00?ie=UTF8&psc=1
2)-Micro Usb HUB Adapter with Power, SUYAMA 3-Port Charging OTG Host Cable Cord Adapter for TV Stick, Raspberry Pi 2 3 Pi Zero Android Smart Phone Tablet…
https://www.amazon.it/gp/product/B078M3Z84Z/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
You can connect USB keyboard, USB stick, USB mouse or 4-port USB hub.
Greetings
Sabino1943
