Corebook Pro Function Key Behaviour
Is there a BIOS version, for the Corebook Pro, that allows for the behaviour of the function keys to be changed, so they are F1, F2 by default?
I do not know, I do not have that model.
Write to service@chuwi.com and wait for a response
Same with the Corebook X. F1 turns the screen off. send help!
Function keys F1, F2, F3 … work in combination with the Fn key
I contacted to aftersale-service@chuwi.com, then I got new EC(Embeded Controller) file.
New EC is version ‘CH-EC-V1.8.0’.
The new EC, I can use F1, F2… without FN key combination.
Yes, it is the second option for those who need the default function keys.
I do realize that but it’s a muscle memory thing that I had to retrain.
I sent a message to the official email address I specified, but I didn’t get a reply.
Do I need to attach a photo of the product serial number, etc.?
If you purchased from Amazon’s CHUWI, you will see the seller in Amazon’s purchase history and you will receive a reply as soon as you contact us.
