Hello, I would like to unlock the FN key as I cannot use the F1-F12 keys. I have tried on the Bios but there is no option and on the keyboard there are no indications. How should I do?
Howdy Maji.
I’d like the same as you.
Did you find any solution?
Cheers.
I could solve the issue!
I contacted to aftersale-service@chuwi.com, then I got new EC(Embeded Controller) file.
New EC is version ‘CH-EC-V1.8.0’.
Yes, it is the second option for those who need the default function keys.
How did you install this file to the system?
Hi Alaim
Chuwi send me update guide also.
I copied the EC files to USB memory, and boot from USB.
Then EC update process started automatically.
HI
please share the file
Hi Bandermon
I’m not sure if I can share it with you, so please contact aftersale-service@chuwi.com to get it.
Hello everybody
I received the file from support, but I am unable to update.
here is the screen that appears to me.
could someone help me?
plz give me i got same problmem corebook pro
share it plz … got this problem and any ask me
SHARE IT PLZ I GOT PROBLEM
