Hello all!
Corebook X 2022 came with SATA SSD in single M.2 slot (1 TB Netac in my case). Does anybody know - will it support NVMe SSD or motherboard doesn’t support it? May be anybody try to do this upgrade?
Hello all!
I just installed 2 NVME SSDs in 2 newly purchased Corebook X, and they work perfectly.
In the first Corebook I installed a 1TB Reletech P400 and in the other unit a 2Tb Reletech P400 Q. Both work perfectly.
Many thanks for info!
On a general note, if there’s NVMe support, you should see an empty PCI-E port:
Win-X, to start Device Manager
On CoreBook 2021 there’s only this one for M.2 NVMe and one more (#8) for the (non-removable) Wi-Fi card.
