Есть ли какая нибуть нормальная утилита или еще что то для регулирования оборотов вентиляторов? изменение в BIOS ноутбук игнорирует, пользоваться не возможно, OC Windows 11
Can you change the parameters in the bios? What version do you have? Can you attach a photo?
It’s very strange. I changed the settings in the bios and they didn’t work at first, but now I turned on the laptop and the settings are applied, now nothing is making noise.
But there are no settings in the BIOS that you are talking about! Can you take a picture?
Блин, вышел из биоса и он опять начал шуметь, как же я ненавижу этот ноут
Видимо еще от производителей не дождусь ответа
You have an “older” BIOS version (2.22.1284) than mine 2.22.1289.
However, you manage to have the changes enabled in the “Advanced” section.
Did you do anything in particular to enable the change in the BIOS?
Andrea giveme bios link i want to download it and install
You should be careful with each model; it has several different series and BIOS versions.
This moderator can provide the link to your exact BIOS version: @ChuwiESnotactive
I can´t control my Fan speed nothing, i have the same like @Andrea82 only Ctrl Fn Reverse on Advanced Tab sadly, @ChuwiESnotactive is there a way for us to also control the fan speed via bios update ? Thank you.
Write to service@chuwi.com, so they can ask Tech if possible update
