CoreBook X Pro i5 Anable to install drivers
I bought it from Banggood.
Serial number is : CoBXProQ512G21051507
Bought on 2022.
Cant see Network and Audio drivers. I tried several drivers found, but nothing works. that happens after returning from windows 11 to windows 10.
I need the drivers
My
You can install Avast Driver Update
I tried.. It needs connection to internet. So it is not updating’
It doesn’t connect via Wi-Fi. You can check if it connects via the network.
You can contact support.
Avast was working for all drivers except I2S sound driver
I have a CoreBook XPro laptop and I’m experiencing no sound at all on Windows.
In Device Manager, the audio section only shows:
Intel® Smart Sound Technology (Intel® SST)
Intel® Display Audio
However, there is also an unknown device under “Other devices”:
Device name: Multimedia Audio Controller
Hardware ID: PCI\VEN_8086&DEV_9DC8&SUBSYS_02062782
This corresponds to the Intel Smart Sound Technology Audio Controller, but it seems that the Realtek Audio driver (codec) required for the SST controller is missing.
As a result, I have no playback devices available and no sound output.
I’ve tried reinstalling Intel SST and updating Windows, but the problem persists.
Could you please provide the correct Audio Driver package (Intel SST + Realtek) for the CoreBook XPro model?
Ideally, a ZIP or EXE installer that includes both the controller and codec drivers.
Thank you very much!
