for certain reasons I had to reinstall the laptop on Windows 11 and the sound driver and touchpad stopped working
Please give me your Serial number
Addition: sound only works through bluetooth headphones
Check if these drivers help
i dont know how to install drivers
Check this manual
Hi.
Had similar issues, the naming on the drivers are very hard to ‘decode’…
I used Snappy Driver Installer Origin to find drivers. Not CCleaner (you have to input your payment info there)
Snappy Driver Installer Origin (make sure to get Origins, not one without it) Link here: https://www.glenn.delahoy.com/downloads/sdio/SDIO_1.13.4.771.zip
Worked for all drivers, as far as I can see… Good luck!
