CoreBook Xpro i5 CWI530 - Missing Audio and USB storage driveers
Hi Falks,
I just re-installed WIndows 11 and the following deivices are not working on my CoreBook Xpro i5 CWI530:
  • Audio device is not recognized and so no audio can be reproduced, worked fine before re-install
  • USB Drives: USB drives are shown in windows device Manager but no driver is installed and so they cannot be accessed, worked fine before re-install and the same drives works fine on other PCs
I also tried all the drivers that i found on this same forum without luck, could you please share the latest drivers(the page to download them by myself is not working)? my Serial Number is: CoBXProQ512G21051585
@ChuwiService @ChuwiESnotactive
Can you please send me a picture of the back of the laptop i cannot find that serial number
Hi, sure here the picture, thank you for your help
Can you tell us the CPU , it may sound weird but this is one of our first models and its being hard to find the files, because with the Serial number is not the same. Do you know which proccesor has?
Yeah sure no worries, it’s an i5-8259U
Hi @ChuwiESnotactive any update on this? Thanks
Hi @ChuwiESnotactive any update?
Sorry for the delay
I used Snappy Driver Installer Origin to find drivers. Not CCleaner (you have to input your payment info there)
Snappy Driver Installer Origin (make sure to get Origins, not one without it) Link here: https://www.glenn.delahoy.com/downloads/sdio/SDIO_1.13.4.771.zip
Worked for all drivers, as far as I can see… Good luck!
