I’m just wondering if anyone has the audio drivers. The SSD failed so I had to downgrade to Windows 10. I tried everything that I could find off of the internet but nothing has worked for me. All I could do is connect a BT speaker. The Intel SST audio driver from SDI does not work. Nothing from Avast updater. I’m close to crying
Have you tried Chuwi support center (OS And Driver Support)?
I have tried the serial you posted, but it is not there, but I would tell you to check it again. Like it says in the web:
“Tip: Please pay attention to the following easily confused characters when entering your serial number: Capital “I” (eye) ↔ lowercase “l” (L) ↔ capital “L” (L)
Number “0” (zero) ↔ letter “O” (oh)
Number “2” (two) ↔ letter “Z” (zee)
Double-check the serial number on your device label to avoid input errors.“
