Corebook x restart
hello, my corebook x, is restarting all of a sudden, how can I fix it?
does anyone have the same problem?
Hello Ajfh,
Have you checked temperatures? Restarting may be happening due to overheating.
Did you install any new software or windows update recently. If so, try to revert update or remove software.
Usually this kind of issue is caused by some driver issue.
Hi, I had the same problem and the only thing that made the restarts stop was replacing the keyboard. Actually it stopped when I unplugged the ribbon connector from the keyboard to the motherboard. It didn’t return to normal until I replaced the keyboard. GL
