Are there manuals for download for the Hi10 Max (N100 chipset I guess) and the Hi10 Max keyboard? US-English version probably, if it matters. In particular I’d like to lock the Fn keys to emit Fxx by default instead of volume, play, brightness, etc. Thanks!
So let me try to understand, you want the keys to be actually just F1 F2 F3
Not function as volume, display etc…?
Exactly. I use applications that make heavy use of the F2-F12 keys, and needing to hold down the Fn key every single time to use F1-F12 is a pain.
Also, downladable manuals for the Hi10 Max and the keyboard?
Thanks!
Wellp, according to Chuwi Official Support ticket Accessories issue(26986),
Sorry, keyboard settings cannot be changed on this model.
As for downloadable product manuals, they sent me this URL,
Wellp, it appears, at least sometimes, the Fn key works like Caps Lock, so instead of holding down the Fn key and pressing one of the top row keys, you press Fn by itself to toggle the top row between sending Fx or the volume/brightness/play/pause etc. The trouble is, there’s no way to tell which mode the top row is in before pressing a top row key. Fun!
