Hi guys, I just received my new tablet. I have a problem with add on keyboard. Seems like blue Fn key is turned on so it tyles numbers instead of letters. It should be the opposite. I would like to press the Fn key and have numbers. How to change it
To activate and deactivate the numbers of the alphanumeric keyboard you must press Fn and numeric block, this key that is usually at the top right
Yes, that was it. Thank You. It was just a NumLk:) It is on by default.
