Please eliminate the need to press the Fn key simultaneously
Is there a way to lock the Fn key on the Hi10 Max? It’s inconvenient to have to press the Fn key simultaneously when using the F1-F12 keys.
Right now i dont have the Hi10Max in the office to check, but you can see in BIOS if this option appears, but as far as i remember , it does not.
According to the response I got from support ticket Accessories issue(26986), apparently not at this time.
It appears, at least sometimes, the Fn key works like Caps Lock, so instead of holding down the Fn key and pressing one of the top row keys, you press Fn by itself to toggle the top row between sending Fx or the volume/brightness/play/pause etc. The trouble is, there’s no way to tell which mode the top row is in before pressing a top row key. Fun!
