Hi10max fn key lock
How to disable fn key? there is no option in bios, nor fn+caps working. is there any bios updates?
You Cant is something that comes with the tablet.
But i will ask if possible to do something
It helped me - FN + WIN, press again to off
thanks a lot!
At least for me, Fn works kind of like Caps Lock, toggling between the top row sending F1-12 or the volume/brightness/play/pause/etc. Fn+Win does the same thing as just Win. Unfortunately, unlike Caps Lock, there’s no handy LED indicator or any other way to tell which mode Fn is in before pressing a top row key.
