Does anyone know if it’s possible to fn lock the keyboard? I would like to use the fn keys (specifically the navigation ones) all the time and only occassionaly switch to the numbers. My hope is that there is some hidden keyboard combination… thanks in advance
Standard key combination to lock function buttons is FN + ESC or FN + CAPS
There are more details about this here.
Hope one of these helps.
