I buy a new Etpad Max and the seller inform me i can upgrade ssd, today receive the tablet and dont have screws or lid for that change
I answered myself, the screen comes under pressure, it comes off easily with a credit card, carefully you remove the staples all around. Remove the screen, be careful with its flexor cable, inside you can see the SSD disk, you remove the screw and change it, you put the screw back and that’s it. In my case, I cloned the original disk (rayson 512gb) and put a 1tb kingston nv2 that I bought cheap on sale.
En español:
me contesto a mi mismo, la pantalla viene a presion, sale facil con una tarjeta de credito, con cuidado le safas las grapas por todo alrededor. Quita la pantalla, ten cuidado con su cable flexor, Dentro se ve el disco ssd, le quitas el tornillo y lo cambias, le vuelves poner el tornillo y ya esta. En mi caso, cloné el disco original (rayson 512gb) y puse un kingston nv2 de 1tb que compre barato de oferta.
This video explain all Is for another model but is the same. Este video lo explica todo. Es para otro modelo pero se hace exactamente igual. the seller provided it to me. El vendedor me lo proporcionó. I hope help others. Espero ayude a otros.
Muchas gracias por aportar esta info
