Hello.
Has anyone tried upgrading the Hi10Max SSD?
Could you tell us what it is like?
Thanks!
You need to send it to a repair store, as everything is soldered , and to remove the case you need a special machine.
Hello! I just upgraded to a 2TB SSD, and it worked perfectly—super easy.
I started from the bottom right, using a thin plastic piece, and carefully opened the entire edge, revealing the internal part. Then, I simply replaced it.
It’s an upgrade I recommend to everyone.
Thats great, but we still dont recommend opening it ![]()
Just in case other customers are curious could you please send the brand of the SSD you bought?
