Fan Problem Gemibook Pro
:flushed: They also changed the info in the product I bought in their AliExpress store. Seems that they’re doing some downgrade to save costs and increase profits… Or it’s a strategy to finish their Gemibook standard stock…
Anyway if I were you I’d look for another brand and model, the fan noise of the Gemibook ā€˜Pro’ is pretty loud and annoying
Thanks for the advice. I also ordered on aliexpress, but now they want to send me a cheaper version or to cancel the order myself, I don’t want to do that because as far as I know aliexpress penalizes sellers who do not send the item that the buyer paid for.
I think your fan is broken. I have a GemiBook pro 12gb 256
When I measure my Fan dB with a 2 cm space from every side of my laptop I get 25dB\30dB on a hard wooden surface and that’s max. Its less on a soft surface. You must know that normal 10 fingers typing keystrokes makes about 40 - 60 db.
My fan has broken down, it has started to make an unbearable noise (it has never been a particularly quiet fan, it must be of poor quality).
Is there still no way to disable it by software?
In the BIOS there are a lot of options but they seem like decoration.
image from GemiBook Pro 14 - right mouse click on touchpad isn“t working and the fan is running on full speed - #5 by JuD.S
