Serial number ZFreeBCY2H220200404 / Purchased Aliexpress in 2023
Board: S105JW rev 1.2
Bios: ZW-BI-135-S105JWR120-JBC / EC ver 01.09
Problem: BIOS settings are not saved.
The laptop has thermal issues and now it is running without battery. So RTC should be lost when power is unplugged, but BIOS settings (such as disable Fast boot) should be persistant.
I need help to figure out how to unlock this situation. Being able to modify the CPU voltages (undervolting) will help to mitigate the temperature problem. Any advice on how to get the BIOS settings to save?
