Freebook N100 not recognizing external monitor or tv
External monitor/tv connection setup
How do I connect with adapter, which slot, etc? My CHUWI N100 doesn’t seem to recognize any device so far. Can I connect USB C to Tv USB? OR type C adapter to tv usb?
What do you mean it does not seem to recognize any device¿
You need to Use USB C in one End and the other would be HDMI or screen
Maybe another user can recommend you a cable that they may be using with their freebook, so you can buy the same one.
Theres no USB-C DisplayPort (DP Alt Mode) output as far as I understand, unfortunately this realisation came to me after I bought usb-cDp cable :confused:
So the only way to connect to the external screen is to connect it wirelessly or through any other USB-C hub/dock like a steamdeck’s, samsung’s or any other, looking something like this: USB-C Adapter from Apple
