Minibook X N100 External Monitor over USB-C Dock not working
Device: CHUWI Minibook X N100
Purchased from www.chuwi.com in 2024.
Serial Number: ZZMinBXHY4H240701740
I have been trying to connect my minibook with an external monitor over a USB-C Dock. The dock supports USB-C Alt Mode for video output, but when I connect it to the laptop nothing happens.
The dock is a Lenovo Universal USB-C Dock model “40AY”. I have tried different USB-C cables (which work with other computers), with also different HDMI cables and different monitors. Nothing seems to work.
I’m running Debian 13 “Trixie” with kernel version 6.12.57.
Here is the dmesg output:
[ 1196.102750] usb 1-4: new high-speed USB device number 23 using xhci_hcd
[ 1196.261856] usb 1-4: New USB device found, idVendor=17ef, idProduct=30af, bcdDevice=60.70
[ 1196.261866] usb 1-4: New USB device strings: Mfr=10, Product=11, SerialNumber=0
[ 1196.261869] usb 1-4: Product: USB2.0 Hub
[ 1196.261871] usb 1-4: Manufacturer: Lenovo
[ 1196.264063] hub 1-4:1.0: USB hub found
[ 1196.264393] hub 1-4:1.0: 3 ports detected
[ 1196.546718] usb 1-4.1: new high-speed USB device number 24 using xhci_hcd
[ 1196.642984] usb 1-4.1: New USB device found, idVendor=17ef, idProduct=30ac, bcdDevice=51.54
[ 1196.642993] usb 1-4.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1196.642996] usb 1-4.1: Product: USB2.0 Hub
[ 1196.642998] usb 1-4.1: Manufacturer: VIA Labs, Inc.
[ 1196.643000] usb 1-4.1: SerialNumber: 000000001
[ 1196.644594] hub 1-4.1:1.0: USB hub found
[ 1196.644957] hub 1-4.1:1.0: 4 ports detected
[ 1196.770702] usb 2-3: new SuperSpeed USB device number 11 using xhci_hcd
[ 1196.818135] usb 2-3: New USB device found, idVendor=17ef, idProduct=30ab, bcdDevice=51.54
[ 1196.818144] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1196.818146] usb 2-3: Product: USB3.1 Hub
[ 1196.818148] usb 2-3: Manufacturer: VIA Labs, Inc.
[ 1196.818149] usb 2-3: SerialNumber: 000000001
[ 1196.820261] hub 2-3:1.0: USB hub found
[ 1196.820592] hub 2-3:1.0: 4 ports detected
[ 1196.890720] usb 1-4.3: new full-speed USB device number 25 using xhci_hcd
[ 1196.990951] usb 1-4.3: New USB device found, idVendor=17ef, idProduct=30a9, bcdDevice=d0.d0
[ 1196.990960] usb 1-4.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1196.990963] usb 1-4.3: Product: 40AY
[ 1196.990964] usb 1-4.3: Manufacturer: Lenovo
[ 1196.990966] usb 1-4.3: SerialNumber: 1S40AYZVT0KNV7
[ 1197.214739] usb 1-4.2: new full-speed USB device number 26 using xhci_hcd
[ 1197.321838] usb 1-4.2: New USB device found, idVendor=17ef, idProduct=30b0, bcdDevice= 0.43
[ 1197.321849] usb 1-4.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1197.321852] usb 1-4.2: Product: ThinkPad USB-C Dock Audio
[ 1197.321854] usb 1-4.2: Manufacturer: Lenovo
[ 1197.321856] usb 1-4.2: SerialNumber: 000000000000
[ 1197.364560] hid-generic 0003:17EF:30B0.0013: hiddev0,hidraw1: USB HID v1.11 Device [Lenovo ThinkPad USB-C Dock Audio] on usb-0000:00:14.0-4.2/input3
[ 1197.426710] usb 1-4.1.3: new high-speed USB device number 27 using xhci_hcd
[ 1197.544645] usb 1-4.3: USB disconnect, device number 25
[ 1197.570509] usb 1-4.1.3: New USB device found, idVendor=17ef, idProduct=30ae, bcdDevice=51.43
[ 1197.570517] usb 1-4.1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1197.570519] usb 1-4.1.3: Product: USB2.0 Hub
[ 1197.570521] usb 1-4.1.3: Manufacturer: VIA Labs, Inc.
[ 1197.570522] usb 1-4.1.3: SerialNumber: 000000001
[ 1197.572033] hub 1-4.1.3:1.0: USB hub found
[ 1197.572313] hub 1-4.1.3:1.0: 4 ports detected
[ 1197.638785] usb 2-3.1: new SuperSpeed USB device number 12 using xhci_hcd
[ 1197.655347] usb 2-3.1: New USB device found, idVendor=0bda, idProduct=8153, bcdDevice=31.23
[ 1197.655354] usb 2-3.1: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[ 1197.655357] usb 2-3.1: Product: Realtek USB LAN
[ 1197.655359] usb 2-3.1: Manufacturer: Realtek
[ 1197.655360] usb 2-3.1: SerialNumber: 321000001
[ 1197.727055] r8152-cfgselector 2-3.1: reset SuperSpeed USB device number 12 using xhci_hcd
[ 1197.798801] r8152 2-3.1:1.0 eth0: v1.12.13
[ 1197.839237] r8152 2-3.1:1.0 enxf8ce720d49d4: renamed from eth0
[ 1197.879127] usb 2-3.3: new SuperSpeed USB device number 13 using xhci_hcd
[ 1197.925963] usb 2-3.3: New USB device found, idVendor=17ef, idProduct=30ad, bcdDevice=51.43
[ 1197.925986] usb 2-3.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1197.925993] usb 2-3.3: Product: USB3.1 Hub
[ 1197.925998] usb 2-3.3: Manufacturer: VIA Labs, Inc.
[ 1197.926003] usb 2-3.3: SerialNumber: 000000001
[ 1197.930049] hub 2-3.3:1.0: USB hub found
[ 1197.930393] hub 2-3.3:1.0: 4 ports detected
I have tried both USB-C ports in my laptop, and I have tried the dock with other devices and it seems to work. The dock says that it supports both Thunderbolt and USB-C Alt Mode.
Note: I have seen other posts here where they mention that sometimes it works with one port but not the other, or with one cable but not others. I have tried both ports, and multiple cables, and I have used these cables to connect the dock to other computers successfully. Also, the USB-C Dock firmware is up to date, I’ve updated it recently.
It looks like the closest issue is the post in here USB-C is not working with external monitors - #19 by ChuwiESnotactive describing how some monitors just don’t show up as a monitor in dmesg (like here).
This is a user forum; no one from Chuwi monitors it.
I think Chuwi doesn’t have Linux support
I have an N150, running kernel 6.18.2 currently, but I struggled with this back when.
I believe both ports worked for direct laptop to monitor connection. I can’t test atm. I would strongly suggest you confirm this works for one or both of your ports. If it doesn’t, the dock is likely not going to work for you. You’ve already tried some cables. If you happen to have a usb-C to hdmi cable that is known to work and an hdmi monitor, that is probably the best baseline test.
The biggest issue when shopping for a portable hub I discovered was the near impossibility of determining if the hub actually supported video pass though. Furthermore, if you’re like me and have a portable monitor, it has to support pass through as well as have enough power.
So, try the baseline test, then become very suspect of your hub.
Running a Minibook X N100 with Arch Linux kernel 6.18.7 w/KDE Plasma 6 on Wayland. I have a USB-C dock I just tested without any trouble. Tragically, it’s a generic 9-in-1 dock from Amazon with no name brand (CHZOON) I got in 2019. The dock is no longer available to link. Sorry, I don’t have a Thunderbolt dock with USB-C alt mode to test.
