Hello, when I use a bluetooth device (mouse, gamepad, etc.) on Windows 11, the device will pair ok and work, but it will not auto reconnect after restarting the laptop or turning off the device. Does anyone know how to fix this?
My bluetooth drivers are updated to the latest 20.100.10.7. All power saving features are turned off for bluetooth.
Found the fix. I had to install the latest Intel Proset/WIFI drivers (22.140.0). This installs the latest drivers for the Intel 3165 chipset.
EDIT: I should clarify, I removed and reinstalled Windows 11. When Windows installed/updated the drivers for the Intel 3165, I had a mismatch of drivers between the Wifi and Bluetooth (which are from the same chipset). Bluetooth should show drivers 20.100.10.7 and 3165 (WIFI) should show 19.51.40.1.
