Gemibook Pro - no sound after fresh windows install
te recomiendo uses para actualizar easy driver en su version de prueba y al instalar optes por la opcion manual… al terminar de descargar se abre la carpeta de ubicacion de los archivos necesario y esa carpta la llevas a Descargas. luego desde el adminstrador de dispositivo vas actualizas el dispositvo faltante
believe me I installed a lot of drivers and also exact these what i have now on the pictures. but still i had "no audio device installed’ at least now works everything as it should
Trust me - there is VERY SIMPLY way to make sound work on re-installed Windows 10 (recover drivers)
  1. Download original CHUWI Gemibook Pro drivers set (check forum for links)
  2. Go to INTEL site and download Graphic (yes-yes! Its integrated with sound) driver: Search - Intel.com
    Exactly this one works for 5100 CPU: “Intel® 7th-10th Gen Processor Graphics - Windows*”
    Then install it (“repair”) and re-boot laptop.
    After this check device manager and manually update drivers from previously downloaded original drivers set (see point 1)
    Enjoy! :slight_smile:
