Does anyone know if there are any touchpad drivers/software beyond the generic drivers that come with the Gemibook? I am so bummed about not being able to adjust the sensitivity.
Download this
It will scan and update everything.
Thanks. This looks really great for Intel drivers. However, the touchpad does not appear to be made by Intel. According to the BIOS, it looks like it is made by ALPS? Maybe I should change the topic of this post to ALPS drivers.
The installed drivers are good enough.
Assuming you have windows 10
Go All Settings> Devices > Touchpad. You can change the touchpad sensitivity there
Thanks for the response. However, changing the touchpad sensitivity in Settings does nothing to reduce the sensitivity.
