I need help with this. My laptop suddenly became like this.
I don’t know what to do. My laptop is Gemibook XPro.
What happens if you enter one of the options that the menu gives you ?
Probablemente tengas que reinstalar el sistema
¿Qué estabas haciendo antes de que eso ocurriera?
I didn’t do anything to that laptop. When I opened it, it just show that.
Please HELP ME!
I need my works. My paper is near deadline and my works are in my laptop.
English only please.
I don’t wanna click any buttons. I might get it worsen.
You can enter these two options and say what to show in the menu.
recovery enviroment
startup settings
There are several ways to repair Windows
How to repair Windows from the terminal
There must be some exit button or you press to turn off the computer
If you want to recover your files, you can start with Live Linux and view the hard drive with your information and copy it to an external hard drive or USB flash drive.
YOu need to reinstall the system
Go here and download the OS and the Drivers
