Hi! I’m having some trouble since the 1st installation: windows can not complete the installation. How can I do now?
I have the same issue. Is there a solution?
Hi there,
I had resolved the issue by doing the installation without connection to the internet, because the pc tries to connect to MS server and make sure that we have the latest version of Windows. Therefore, just do the setup without connection and once you are installed then you connect to your wifi and all will be good.
Enjoy
