Herobook wont boot
And pc wont boot anyway
(in photo you see battery connected, but i have disconnected)
The software can’t work with 1.8 voltage IC without adapter.
Try to use Programmer V1.18 or NEOPROGRAMMER with 1.8v adapter. If that doesn’t work, you need to unsolder IC. The clip is not stable enough.
I noticed that the clip is of low quality, but I guess that wasn’t the problem. Besides, now I have no more answers from the chip, which I think did not like the 3.3 volts. I try to unsolder it, and maybe buy another one, since it costs very little. I also try the other programs you indicated to me. Thank you very much again. If I get results I update the post
hello one question aleady flash bios?? final solution is desolder chip???
need a converter to 1-8v??¿??¿?¿???’
thanks
hello i have the same problem. When I power on the herobook it stucks at the CHUWI logo screen. I used the CH341a with AsProgrammer to read and write the bios. I can read but I cant write because the bin file is larger(8MB) that the ic memory(4MB). I have the GD25LB64CVIG. Maybe there are any instructions for IC xml file to read and write this chip? (like id, page, size, spicmd etc)
