Hi i recently installed q4os linux (based on debian) which came with 6.1 Kernel.
after upgrading to kernel 6.7, it uses directly AX101 Intel Wifi chipset after reboot
With tweaking firmware files, it also recognized Bluetooth properly ![]()
kernel update:
sudo qrepoadd --gui
…then select “bookworm-backports”
then sudo qinst-kernel-bpo
for bluetooth firmware:
download ibt-4040-1050.sfi and ibt-4040-1050.ddc
from https://anduin.linuxfromscratch.org/sources/linux/firmware/intel
and place it under /lib/firmware/intel
