HeroBox Pro Intel Jasper Lake N4500 Mini PC DRIVERS
From my HeroBox HeroBox Pro Intel Jasper Lake N4500, tested on Windows 11 build 22000.71, audio / mic jack working.
Model: HeBoxP256G210502815, using Double Driver 4.1.0
https://drive.google.com/drive/folders/1bMaa9R6RV0MBX2GchHFWCuSbHm3h5n2k?usp=sharing
You’re an angel , thank you very much man , all drivers worked properly .
There are official and non-official. which one do you recommend on Windows 11?
hola , he reinstalado windows 10 home 22H2 19045.2486 Windows Feature Experience Pack 120.2212.4190.0 , no funciona el audio por salida mic jack , si funciona por hdmi , descargue los drivers , después los instale intel(R) smart sound y el realtek r2.82 de 64 bits y sigue sin funcionar la salidad de mic jack , windows dice ningun dispositivo de salida de audio instalado . ¿ Me pueden decir que driver en especifico es para la salida de mic jack o que configuración necesito ?
Hello, I have reinstalled windows 10 home 22H2 19045.2486 Windows Feature Experience Pack 120.2212.4190.0, the audio does not work by mic jack output, if it works by hdmi, I downloaded the drivers, then I installed intel(R) smart sound and realtek r2.82 64 bits and still does not work the mic jack output, windows says no audio output device installed. Can you tell me what specific driver is for the mic jack output or what configuration I need?
qualcuno è riuscito ad installare win10 con questa immagine?
