Bueno estoy intentando instalar android, siguiendo todos los pasos del manual y cuando estoy en el phone flash el doy a start, comienza 10 segundos y la tablet se reinicia y sale la pantalla del androide verde con la tapa abierta y ya me da error el phone flash.
pego el log
Intel® Phone Flash Tool - Logs generated on 2024-05-08T15:38:59
Intel® Phone Flash Tool V 5.3.4.1 x86 (build on Thursday October 15th 2015, 13:48:49 UTC)
OS: Windows 8.1 (x64)
05/08/24 15:37:28.348 DEBUG Json Flash file parsed (C:/Users/andres/.flasher/.configs)
05/08/24 15:37:29.210 INFO Intel(R) Phone Flash Tool V 5.3.4.1 x86 (build on Thursday October 15th 2015, 13:48:49 UTC)
05/08/24 15:37:29.210 INFO Using xFSTK Downloader version: 1.8.1
05/08/24 15:37:29.300 INFO Using DFU Downloader version: 0.8.1-msvc
05/08/24 15:37:29.312 INFO Using DnX Firmware Downloader version: 1.0.0.0 (No API)
05/08/24 15:37:30.518 INFO Using Intel Command Line FlashTool v.2.50 (Download Library v.5.18,0.0 )
05/08/24 15:37:30.577 INFO Using Android Debug Bridge version 1.0.32
Revision cc6ae925e394-android
05/08/24 15:37:30.577 INFO OS version detected: Windows 8.1 (x64)
05/08/24 15:37:31.683 INFO SSL supported: Yes
05/08/24 15:37:31.683 INFO Using TMT API version: 1.8.0-0
05/08/24 15:37:31.683 TRACE System PATH: C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0;C:\Windows\System32\OpenSSH;C:\Program Files (x86)\Intel\Phone Flash Tool;C:\Users\andres\AppData\Local\Microsoft\WindowsApps;
05/08/24 15:37:31.683 TRACE Application path is C:/Program Files (x86)/Intel/Phone Flash Tool
05/08/24 15:37:31.683 TRACE Working directory is C:/Program Files (x86)/Intel/Phone Flash Tool
05/08/24 15:37:31.683 TRACE Status server disabled
05/08/24 15:37:31.750 TRACE TEMP folder location: drive C:/ (‘C:/Users/andres/AppData/Local/Temp’)
05/08/24 15:37:31.750 INFO Disk space available on drive C:/ : 76.14 GB
05/08/24 15:37:31.853 INFO Adb and fastboot binaries OK
05/08/24 15:37:32.069 INFO [Port 8/2] New device detected on 8/2 (id=0801000000000001)
05/08/24 15:37:32.733 INFO Phone Flash Tool initialized successfully
05/08/24 15:37:44.448 DEBUG Json Flash file parsed (C:/Hi10 Pro Android images-factory-cw_hi10pro_eu-2.0-5.1.1-B2016081102-signed)
05/08/24 15:37:44.651 INFO Ready to flash!
05/08/24 15:37:44.656 DEBUG FlashConfiguration:
name=blank
startState=dnx_os
brief=Erase the phone and flash all partitions, including factory
description=Erase all content, rewrite partition table and flash all partitions
documentation=
hiddenToEndUser=no
id=blank
cmd[0, m=no, t=60000, s=no] fastboot “flash” “fw_stage2_osdnx” “C:\Hi10 Pro Android images-factory-cw_hi10pro_eu-2.0-5.1.1-B2016081102-signed\firmware.bin”
cmd[1, m=yes, t=5000, s=no] Sleeping for 5 seconds
cmd[2, m=yes, t=60000, s=no] Wait for device with status dnx_os
cmd[3, m=yes, t=60000, s=no] fastboot “flash” “osloader” “C:\Hi10 Pro Android images-factory-cw_hi10pro_eu-2.0-5.1.1-B2016081102-signed\loader.efi”
cmd[4, m=yes, t=60000, s=no] fastboot “boot” “C:\Hi10 Pro Android images-factory-cw_hi10pro_eu-2.0-5.1.1-B2016081102-signed\loader.efi”
cmd[5, m=yes, t=500, s=no] Sleeping for 0.5 seconds
cmd[6, m=yes, t=60000, s=no] Wait for device with status pos
cmd[7, m=yes, t=60000, s=no] fastboot “oem” “unlock”
cmd[8, m=yes, t=60000, s=no] fastboot “flash” “oemvars” “C:\Hi10 Pro Android images-factory-cw_hi10pro_eu-2.0-5.1.1-B2016081102-signed\oemvars.txt”
cmd[9, m=yes, t=60000, s=no] fastboot “flash” “gpt” “C:\Hi10 Pro Android images-factory-cw_hi10pro_eu-2.0-5.1.1-B2016081102-signed\gpt.bin”
cmd[10, m=yes, t=60000, s=no] fastboot “flash” “bootloader” “C:\Hi10 Pro Android images-factory-cw_hi10pro_eu-2.0-5.1.1-B2016081102-signed\bootloader”
cmd[11, m=yes, t=60000, s=yes] fastboot “oem” “rm” “/ESP/BIOSUPDATE.fv”
cmd[12, m=yes, t=60000, s=yes] fastboot “flash” “ifwi” “C:\Hi10 Pro Android images-factory-cw_hi10pro_eu-2.0-5.1.1-B2016081102-signed\afu.bin”
cmd[13, m=yes, t=60000, s=no] fastboot “erase” “misc”
cmd[14, m=yes, t=60000, s=no] fastboot “erase” “persistent”
cmd[15, m=yes, t=60000, s=no] fastboot “erase” “metadata”
cmd[16, m=yes, t=60000, s=no] fastboot “format” “config”
cmd[17, m=yes, t=60000, s=no] fastboot “format” “cache”
cmd[18, m=yes, t=600000, s=no] fastboot “flash” “system” “C:\Hi10 Pro Android images-factory-cw_hi10pro_eu-2.0-5.1.1-B2016081102-signed\system.img”
cmd[19, m=yes, t=60000, s=no] fastboot “flash” “boot” “C:\Hi10 Pro Android images-factory-cw_hi10pro_eu-2.0-5.1.1-B2016081102-signed\boot.img”
cmd[20, m=yes, t=60000, s=no] fastboot “flash” “recovery” “C:\Hi10 Pro Android images-factory-cw_hi10pro_eu-2.0-5.1.1-B2016081102-signed\recovery.img”
cmd[21, m=yes, t=60000, s=no] fastboot “format” “data”
cmd[22, m=yes, t=60000, s=no] fastboot “oem” “lock”
cmd[23, m=yes, t=60000, s=no] fastboot “continue”
05/08/24 15:37:44.656 DEBUG Monitoring C:\Hi10 Pro Android images-factory-cw_hi10pro_eu-2.0-5.1.1-B2016081102-signed\flash.json
05/08/24 15:37:44.657 INFO Flash file C:\Hi10 Pro Android images-factory-cw_hi10pro_eu-2.0-5.1.1-B2016081102-signed\flash.json [blank] loaded
05/08/24 15:37:53.969 INFO [Port 8/2] Start flashing the flash configuration with dnx_os start state for EMMC00128235
05/08/24 15:37:53.969 DEBUG Device is already in the required state, no need to reboot it
05/08/24 15:37:53.970 INFO [Port 8/2] Starting flash …
05/08/24 15:37:53.970 DEBUG [Port 8/2] Waiting for device in dnx_os
05/08/24 15:37:53.970 INFO [Port 8/2] Flash started
05/08/24 15:37:53.970 INFO [Port 8/2] Sleep 500 ms before executing first flash command
05/08/24 15:37:54.470 DEBUG [Port 8/2] Group ‘delete_capsule’ disables command Deleting BIOS capsule file
05/08/24 15:37:54.470 DEBUG [Port 8/2] Group ‘flash_AFU’ disables command Flashing AFU
05/08/24 15:37:54.470 INFO [Port 8/2] Running "C:\Program Files (x86)\Intel\Phone Flash Tool\fastboot.exe" "-s" "EMMC00128235" "flash" "fw_stage2_osdnx" "C:\Hi10 Pro Android images-factory-cw_hi10pro_eu-2.0-5.1.1-B2016081102-signed\firmware.bin" command
05/08/24 15:37:54.608 DEBUG [Port 8/2] sending ‘fw_stage2_osdnx’ (2048 KB)…
05/08/24 15:37:54.608 DEBUG [Port 8/2] OKAY [ 0.068s]
05/08/24 15:37:54.608 DEBUG [Port 8/2] writing ‘fw_stage2_osdnx’…
05/08/24 15:37:54.608 DEBUG [Port 8/2] FAILED (remote: unknown command)
05/08/24 15:37:54.608 DEBUG [Port 8/2] finished. total time: 0.072s
05/08/24 15:37:54.613 WARNING [Port 8/2] Command "C:\Program Files (x86)\Intel\Phone Flash Tool\fastboot.exe" "-s" "EMMC00128235" "flash" "fw_stage2_osdnx" "C:\Hi10 Pro Android images-factory-cw_hi10pro_eu-2.0-5.1.1-B2016081102-signed\firmware.bin" failed
05/08/24 15:37:54.614 INFO [Port 8/2] Retrying "C:\Program Files (x86)\Intel\Phone Flash Tool\fastboot.exe" "-s" "EMMC00128235" "flash" "fw_stage2_osdnx" "C:\Hi10 Pro Android images-factory-cw_hi10pro_eu-2.0-5.1.1-B2016081102-signed\firmware.bin" command
05/08/24 15:37:54.745 DEBUG [Port 8/2] sending ‘fw_stage2_osdnx’ (2048 KB)…
05/08/24 15:37:54.745 DEBUG [Port 8/2] OKAY [ 0.068s]
05/08/24 15:37:54.745 DEBUG [Port 8/2] writing ‘fw_stage2_osdnx’…
05/08/24 15:37:54.745 DEBUG [Port 8/2] FAILED (remote: unknown command)
05/08/24 15:37:54.745 DEBUG [Port 8/2] finished. total time: 0.072s
05/08/24 15:37:54.745 WARNING [Port 8/2] Command "C:\Program Files (x86)\Intel\Phone Flash Tool\fastboot.exe" "-s" "EMMC00128235" "flash" "fw_stage2_osdnx" "C:\Hi10 Pro Android images-factory-cw_hi10pro_eu-2.0-5.1.1-B2016081102-signed\firmware.bin" failed
05/08/24 15:37:54.745 INFO [Port 8/2] Running Sleeping for 5 seconds command
05/08/24 15:37:59.748 INFO [Port 8/2] Command Sleeping for 5 seconds succeed
05/08/24 15:37:59.749 INFO [Port 8/2] Running Wait for device with status dnx_os on port 8/2 command
05/08/24 15:37:59.749 INFO [Port 8/2] Command Wait for device with status dnx_os on port 8/2 succeed
05/08/24 15:37:59.750 INFO [Port 8/2] Running "C:\Program Files (x86)\Intel\Phone Flash Tool\fastboot.exe" "-s" "EMMC00128235" "flash" "osloader" "C:\Hi10 Pro Android images-factory-cw_hi10pro_eu-2.0-5.1.1-B2016081102-signed\loader.efi" command
05/08/24 15:38:00.150 DEBUG [Port 8/2] sending ‘osloader’ (5979 KB)…
05/08/24 15:38:00.150 DEBUG [Port 8/2] OKAY [ 0.184s]
05/08/24 15:38:00.150 DEBUG [Port 8/2] writing ‘osloader’…
05/08/24 15:38:00.150 DEBUG [Port 8/2] OKAY [ 0.017s]
05/08/24 15:38:00.150 DEBUG [Port 8/2] finished. total time: 0.201s
05/08/24 15:38:00.150 INFO [Port 8/2] Command "C:\Program Files (x86)\Intel\Phone Flash Tool\fastboot.exe" "-s" "EMMC00128235" "flash" "osloader" "C:\Hi10 Pro Android images-factory-cw_hi10pro_eu-2.0-5.1.1-B2016081102-signed\loader.efi" succeed
05/08/24 15:38:00.150 INFO [Port 8/2] Running "C:\Program Files (x86)\Intel\Phone Flash Tool\fastboot.exe" "-s" "EMMC00128235" "boot" "C:\Hi10 Pro Android images-factory-cw_hi10pro_eu-2.0-5.1.1-B2016081102-signed\loader.efi" command
05/08/24 15:38:00.246 DEBUG [Port 8/2] Device disconnected on 8/2
05/08/24 15:38:00.407 DEBUG [Port 8/2] creating boot image…
05/08/24 15:38:00.408 DEBUG [Port 8/2] creating boot image - 6125568 bytes
05/08/24 15:38:00.408 DEBUG [Port 8/2] downloading ‘boot.img’…
05/08/24 15:38:00.408 DEBUG [Port 8/2] OKAY [ 0.187s]
05/08/24 15:38:00.408 DEBUG [Port 8/2] booting…
05/08/24 15:38:00.408 DEBUG [Port 8/2] OKAY [ 0.003s]
05/08/24 15:38:00.408 DEBUG [Port 8/2] finished. total time: 0.190s
05/08/24 15:38:00.408 INFO [Port 8/2] Command "C:\Program Files (x86)\Intel\Phone Flash Tool\fastboot.exe" "-s" "EMMC00128235" "boot" "C:\Hi10 Pro Android images-factory-cw_hi10pro_eu-2.0-5.1.1-B2016081102-signed\loader.efi" succeed
05/08/24 15:38:00.408 INFO [Port 8/2] Running Sleeping for 0.5 seconds command
05/08/24 15:38:00.916 INFO [Port 8/2] Command Sleeping for 0.5 seconds succeed
05/08/24 15:38:00.918 INFO [Port 8/2] Running Wait for device with status pos on port 8/2 command
