This is my serial number: LQ64G42180304141.
I want to reinstall android, because it is not booting.
It only shows the android logo
Windows 10 is loading normaly.
Thank you in advance. ^^
Thank you for you fast response!
The flashing was successfull but after choosing android, the screen stays blank with this error message:
Failed to Display blt: Invalid Parameter
Failed to display image splash_intel: Invalid Parameter
OK,then please try this one.
http://chuwi.mediafire.com/file/1wxc8u5o4vgs56u/cht_cr_mrd_w-flashfiles-userdebug.softteam_P12B_Ilife_C189B_CW_Hi10_NG_W_DS_V1.0.2.zip/file
I flashed it successfully!
Android starts and works.
But the Touchscreen is working very slow.
Every 4 seconds it will stop working for a few seconds.
Keep in mind that installing Android will lose Windows that you will have to install again.
Only if when downloading and decompressing the Android files, if it contains a “non-erase-all” flash file, using that file to install Android, Windows will not be lost
6, The serial number for HQ64G421803 Download: Android:
Hi10 Pro Android(2018.03)
MediaFire is a simple to use free service that lets you put all your photos, documents, music, and video in a single place so you can access them anywhere and share them everywhere.
Windows:
Hi10 Pro Windows(2018.03):
http://www.mediafire.com/file/bww5l5j56bbi04w/HI10_H_1711XXX.rar/file ( The same as 2017.11 )
Tutorial:
http://www.mediafire.com/file/wayshpo83nmkphu/ChuWi_Hi10_Pro_dual_system_flash_tutorial.docx/file
I flashed this file before.
I tried it again, and now I´m stuck at a blackscreen with the error message I had written before:
Sooo, I tried the Version 1.0.0 of Android from the download section and it works perfectly now ^^.
But I have another question:
I reinstalled Windows 10 and now, the Touchscreen wont work.
Can I have the driver please?
I have the same problem in my tablet, could u please send me the link of the android version 1.0.0.
What is the serial number?
@manonegra222 estoy intentando arreglar mi tablet porque no me funciona ni android ni windows, he descargado creo que los archivos correctos de mi modelo Chuwi Hi10 Plus LQ64G421709.
He seguido el tutorial que hay en un word, primero he empezado con android y me aparece este errror que no consigo que salga adelante:
y en IP flash tool me aparece (“EMMC098BFB72” Flash failed, Device enumeration :
08/11/21 16:43:05.165 ERROR : [Port 1/1/4] Command Wait for device with status pos on port 1/1/4 failed
08/11/21 16:43:05.165 ERROR : [Port 1/1/4] Flash failed (Command type: Device enumeration)
08/11/21 16:43:07.157 INFO : [Port 1/1/4] Device lost on 1/1/4
Por favor me podrias ayudar?. Gracias de antemano, un saludo.
tienes que comprobar primero que el eMMC, que es como el disco duro de un ordenador, no esté averiado y sea ese el motivo por el que te da el error al flashear Android.
Para comprobarlo, ve a la Bios en la pestaña Boot a ver si se reconoce la unidad.
También puedes intentar hacer una prueba: iniciar con un pendrive booteable de Windows 10, pulsando F7 intermitentemente hasta que salga una pantalla de selección de boot de arranque, allí seleccionar el pendrive e intentar instalar Windows, para ver si en la pantalla de dónde quieres instalar Windows, aparece la unidad. Si no sale ninguna es que el eMMC está averiado y no tendrá solución. Sólo podrás instalar Windows en un medio externo, como un pendrive, para poder utilizar la tablet
