Hi10 Go drivers
hello, I’m having a very difficult thing, my touchscreen doesn’t work after the windows 11 update, does anyone have a touchscreen driver? please
Hi there, if your hardware version is with N5100, you can try the above driver set.
Will this device get OTA bios update or do we have to search and update manually? Appreciate if someone can share the link if available. I’m having battery drain even when device is shutdown and hoping an updated bios will help. Cheers!
how to install on windows 10?
Hi all,
I made an account just to share my solution to reversed touchscreen axes problem.
For me it began just after downgrading Win11 to Win10 - sound was gone, touchscreen not working at all. Most issues were solved using @alvinddm drivers package (thx for that), but reversed axes (both X and Y) persisted. I tried all the solutions found on the Internet, but none worked, so I started experimenting. After some time I downloaded an old GoodixTouchDriver from the Lenovo support site (.exe file, just unpacked it, obviously it couldn’t be installed properly). Then I replaced existing new (made in 2021 - 105 kB in size) GoodixTouchDriver.sys file with the old one (made in 2015 - 110kB in size) - it was the only file I changed. Then I installed GoodixTouchDriver Device driver using Device Manager and voila - everything’s fine now. No need to edit touchscreen.gt file, updating anything or installing any additional software. Below you can find the link to the correct driver, just download and install, replacing the old one.
https://www.mediafire.com/file/z2w08q9ul94nmfo/goodixtouchdriver.inf_amd64_03053a481a122327.rar/file
Let us know if this helped you too.
Cheers,
David
Fiz downgrade do windows 11 para o 10 e não precisei voltar para o 11 nem restaurar a imagem continue no windows 10.
Eu usei o pacote de drives da @iuwu871 (ajudou a instalar muitos drivers) mas o touch não voltou, para voltar usem esse link do mega e a seguinte instrução:
Extraia
Abra a pasta goodixtouchdriver
Clique com o botão direito em goodixtouchdriver (informações de configuração) e aperte em instalar, permita tudo logo o touchscreen voltará.
olá, estou com mesmo problema porém não deu certo comigo, o touch funciona descalibrado.
Tem alguma dica?
Thank you for your contribution, but the link controller continues with that problem. Could you please provide us with another solution or share the necessary files to carry out the process you mentioned.
can u pls tell us how to use this set ?
i found the way ! thank u bro
I drop a link and how to install all driver in here for our future if we needed
  1. Driver:
    N5100Hi10Go.rar - Google Drive
  2. How to install all driver: InstallAllInOne.zip - Google Drive
In case you cant download pls contact me though mail: duynq2197@gmail.com
Updated. I resolve this error (Inverted touch in CHUWI Hi10Go N5100)
RESOLVE FILE
Please read REAME.txt carefully.
Because of i dont know exactly what i do so i note everything i did. But its work now
CHUWI Hi10 GO N5100 (WINDOW 10 - INSTALL FROM IMAGE of iuwu871)
REMEMBER REMOVE ALL APPLICATION WHICH INSTALL BY DRIVER TOOL
After all, i make sure that maybe goodix… driver is ok. But something other is not right. So its cause inverted touch. So try to install full driver is not a bad idea.
Hello, here are some drivers for the Chuwi Hi10 Go (N5100) that were automatically installed when resetting Windows and work perfectly (Windows 11): ChuwiHi10go_Win11.zip - Google Drive
P.S.: Sorry for passing them to you like this, I am not an expert programmer or developer, you can install them from the device manager, search for drivers on this computer, and select the unzipped folder, this is for any computer with issues and for computers that are not recognized, I hope it works for you :slight_smile:
Der verwendete Controller GT911 wird vom installierten Treiber mit einem Konfigurationspaket gefüttert. Siehe “GT911 Programming guide” ab Seite 5. Die alten Treiber haben die Konfigurationsdaten von der TouchSetting.gt bekommen unter Punkt: DefaultCFG=0x00…
Das hatte funktioniert. Die neuen Treiber brauchen die touchsetting.gt nicht mehr, die Daten sind fest in der GoodixTouchDriver.sys hinterlegt. Der Knackpunkt liegt in der Beschreibung unter (0x8047). Der Controller akzeptiert nur Versionsnummern die gleich oder neuer sind. Jeder, der versucht hat von einem anderen Hersteller die Touchtreiber zu verwenden, hat dem Controller falsche Konfigurationsdaten mit einer neuen Versionsnummer gegeben. Die funktionieren nun nicht und jeder Versuch, dem Controller ältere Versionen oder eben die richtigen zu geben schlägt fehl. Möglicher Weg: laut dem Datenblatt wird bei der übergebenen Konfiguration von 0x8047 = 0x00 Version “A” übergeben, das heist der Versionszähler auf Start gesetzt. Also folgenden Weg versuchen: eine alte GoodixTouchDriver.sys und eine TouchSetting.gt mit DefaultCFG=0x00 einmalig einsetzen um die Konfig auf “A” zu setzen, dann erst den vermutlich richtigen Treiber verwenden. Achtung: nicht jeder Treiber wird gehen, denn nur weil das GDIX1002 steht, hat die .sys nicht die richtigen Konfigurationsdaten. Der Treiber lässt sich installieren, der Touch wird aber nicht funktionieren. Grüße aus Vechelde! Robert
