Hi there,
I am having issues with Android loading. Everything was functioning perfectly, but the computer now freezes on bootup.
It gets past the INTEL logo and then turns black.
I can press the power button and get the SHUTDOWN menu, but no launcher arrives.
I have looked for the original firmwares for my device through the forum, but have not found anything.
The BIOS and Windows are fine.
I did enter the developer options on Android and turned on OpenGL rendering and touch recognition/notification a while ago. So I am getting notifications of touch input. So I am suspecting that it is a corrupted settings file somewhere.
Any help would be appreciated, either to solve my problem or to get the original firmwares for future use.
Many thanks
