Hi there, bought this Hi10X at Wish and it worked fine from the start. After upgrading to windows 10 Pro by using a W10 Pro license the Touch Screen and Pen stopped working. Also, in de Notification area there’s no longer a setting for screen rotation.
I tried all the Goodix touchscreen downloads I could find on this forum put it keeps on telling : The folder you specified doesn’t contain a compatible software driver for your device : If the folder contains a driver, make sure it is designed to work with Windows for x64-based systems. And so my Hi10X is indeed a 64 bit windows 10 Pro.
I also tried it with a startup disabling the requirement for signed drivers but also after doing a restart like that the driver gives the same error.
Is it true that none of the Goodix Touch drivers support 64 bits or is there a way to install the driver bypassing this error.
