Hi
I can’t access my Hi8 anymore (Windows and Android partition) and need to reinstall it.
Were can I find the latest firmware and roms to do a reinstallation?
thanks in advance for your help.
Hi
Hi Rene_D
From this Hi8 code Q32G22160202855, it is deduced that your Hi8 is not Pro.
If your Hi8 is not Pro you need to download the following Firmware:
-Hi8 (DualOS Windows 10 and Android 4.4 ). You can find it at this Link:
N.B.: Android has no Updates since its inception.
While Windows 10 has Build 1507 Version of 2015/07, but with Windows Update you can update it to the latest Build 19045_2364 (current of December 2022)
If your Hi8 is Pro (Hi8 Pro) you need to download the following Firmware:
-Hi8 Pro (DualOS Windows 10 and Android 5.1). You can find it at this Link:
N.B.: Android has no Updates since its inception. While Windows 10 has Build 1604 Version of 2016/05, but with Windows Update you can update it to the latest Build 19045_2364 (current of December 2022)
While, if you want to install Only Windows 10 you need to download the following Firmware:
-Hi8 Pro(Only OS Windows 10). You can find it at this Link:
N.B.: Windows 10 has Build 1511 Version of 2016/02, but with Windows Update you can update it to the latest Build 19045_2364 (current of December 2022)
Waiting, I greet you
Mr Sabino
Hi Sabino1943
many thanks for sharing.
I have downloaded the two files from [Chuwi Hi8 Dual OS Android4.4 + Windows10 Newest Firmware_192508],
Thanks Rene
Hi Rene
Did you use the password “geekbuying.com” ?.
To Extract these Files you need this Pass.
Let me know. I check if I have something in Archive!.
Mr Sabino
Hi Sabino
I first used the one on the download page “ggekbuying.com” and wondered as it didn’t worked and I received too many errors, then I tried “geekbuying.com” and all was fine. ![]()
Rene
