Hi, I was resetting my HI8 windows tablet, everything went normal until it reached 100% and restart, then prompted a screen saying:
A configuration change was requested to clear this computer’s TPM
Press YES to clear the TPM
Press NO to reject this change request and continue
Do you accept the change?
YES ---- NO
Thing is, touchpad is not working to select YES or NO, and I’m stuck in this screen. I made a research and they suggest to use an OTG cable and a USB keyboard, use the volume up and down buttons, and to clear the bios (pressing power + vol up + vol down for 5-10 seconds), but none of this has worked. Maybe there’s another way to make an USB keayboard to work with this tablet, or to clear the bios.
Please help!!!
