Hibook Pro CWI526 Intel Atom X5-Z8300
Serial number HiB PQ65G45160902040
I attempted to upgrade the BIOS in a CWI526 HiBook Pro using the file at this location:- [HiBook] [Official Version] Chuwi HiBook Bios + Android + Windows download
but now the screen does turn on nothing happens, it does not even attempt to boot.
Ironically the document states the following:-
Flash BIOS(If it’s reinstall system, you can not flash bios,flashing the wrong bios may result in no display,Please be cautious.)
What exactly do you mean by “reinstall system” and is there now a way to recover from this?
That means you’ve broken the device.
How to recover the device:
External BIOS chip: In severe cases, the BIOS chip can be desoldered and reprogrammed externally.
Where can I get the correct BIOS file?
In Chuwi support.
if the device doesn’t start, there’s nothing you can do.
To find out about the BIOS you have to search on Google
I have and I have a programmer that can do the chip, I just need the file to put onto the BIOS chip.
Regards
Stuart Hanson
Mytech Communication Services
Office:- 02 98204459
Mobile:- 0417204459
This document should be read only by those persons to whom it is addressed and the content is not intended
for use by any other persons. If you have received this message in error, please notify us immediately. Please
also destroy and delete the message from your computer. The opinions expressed in this email are those of
the author and do not recessarily represent the view of Mytech Communication Services. The information
contained in this email is not legal advice. Whilst every care has been taken to ensure that this information is
accurate, no warranty of accuracy or reliability is given and no liability is accepted for errors or omissions or
loss or damage suffered as a result of persons acting in reliance thereon.
You should scan any attached files for viruses.
My last answer.
I hope it doesn’t cost you more than a new one.
I wish you good luck.
hello i have done the smae mistake and i asked them for the bios file via email , they did not respond
