Guys after the latest updates , with windows 11 a straight horizontal line appears on the screen.
Do you know any solution on this?
Is the line always in the same place, or does it rotate along with the display when you change orientation to portrait?
In case of the first → Hardware problem, like possible loose cable
In case of the second (likely) → Display driver problem, could be fixed by removing and reinstalling the Intel IGP-driver from device manager or updating it with Intel Driver Assistant.
Yes the line is always in the same place.
It appears after the latest windows update firmware and also it automatically updates the “intel display driver” or something like that , which basically is the graphics
