Hello there,
Well, I have the solution and I can fix it that the Management couldn’t. So first you’ll have to leave the power button pressed. You will notice that the power indicating light has got stopped and again started in the blink of an eye. You will still hold on the power button and then the light will again get stop. After this it’ll remain stop as long as you hold on and you should hold on too. In this way, after a while you’re Chuwi HerBook Pro will boot up and you can accomplish you’re work over there.
Thanks for reading with patience. And yes don’t forget to reply below and let me know whether it was helpful or not
