How to insert a second SSD?
Do all CHUWI LapBooK Pro 14.1 all have a dedicated slot?
Chuwi LapBook Pro with 8GB of Ram and 256GB SSD does not have a second slot for an SSD volume, to expand the storage you will need to remove the original SSD
Thanks for the information! I thought the second slot was hidden somewhere.
But Chuwi says that there is the chance to have a M2 SSD expansion support in the laptop pro.
Is it not correct ?
If your model with internal EMMC you can expance with m.2 slot. There is only one m.2 slot.
