How to install Android on Chuwi Hi10x
How to install Android on Chuwi Hi10 x?
Hello, It only Windows.
What you can try is to have Android within Windows using an emulator such as Bluestacks, Nox or VMware / Virtual box
I try but It work very slowly
Most Android installs work each with their own problems. The best one I’ve found so far is Android x86 version 9. The camera isn’t great and auto rotate doesn’t work. You can get the screen to rotate using an app from the app store. Power management isn’t very good in any version of Android. There are a few install guides here on these forums so just search. You may need to search in other chuwi product types though like the hi 10 plus for example.
