hola buenos dias he comprado una tablet chuwi hi10x que tiene windows 10 y me gustaria instalar android alguien me puede decir como hacerlo y de donde descargarlo gracias
Please use english or translate to english next time.
You can download BlueStacks or Nox Player but you are going to suffer some lagg and hiccups but not that bad.
You can go install this FydeOS basically your Hi10 X turn into Chromebook and you can run android app without any compromise
(i don’t recommend it, if you plan to use Windows Apps. and last time i use it. touch screen does not work and rotation and bluetooth does not work. If you planning to installing the FydeOS My advice BACKUP FIRST EVEN A WINDOWS DRIVER because if you didn’t back up you screw up your Hi10 X)
My advice is wait to Microsoft release Windows Subsystem For Android.
after battling with someone here,
we summarized that there are intel/realtek sound chips or ess chips variant of hi10x/r.
i am using intel/realtek chips and almost everything works for me in fydeos v15.1,
except:
- sd slot
- auto rotate
- sleep.
i boot primeos from usb,
runs ok, except the stylus.
it somehow recognize it but don’t process it correctly,
render it useless
