Has anyone tried installing and using FydeOS on this device?
How well does it work? Do the cameras, stylus, rotation, touchscreen work? And how well?
Regards,
- A
Regards,
I have already given a link to the description of installing FideOS on a Chuwi Hi10 Max - Hi10Max N100, Dual Boot - #5 by SveT1iy
The rotation, the touch screen worked, the stylus was not available at that time, so I can’t say for sure, but most likely, since the touch screen works, the stylus should work. The camera doesn’t work right away, I installed the .apk application separately, it worked tolerably. It was put as a test, I don’t use it now.
Hello, which APK did you use?
Hello.
It was a few months ago, I don’t remember exactly now. I tried a few, but many didn’t work.
OK, thanks anyway. I’m currently running Chrome OS with the Play Store, and everything’s great except for the camera.
You’re welcome!
