Chromebelt! FydeOS v15 made my hi10xr into expensive x86 chromeblet!
FydeOS is chinese made, and not so open source however.
but, in additon to OS flex
  1. it support android 9 runtime, within it the active stylus still have pressure sensitivity and palm rejection
  2. so far i only notice auto rotation not working, but it’s a small thing right?
  3. even play store treat it as chromebook, and can install some chromebook specific apps!
  4. easy dual boot using refind manager.
crazy.
Can you link to download FydeOS?
there are 3 variants of hi10x, 2 use intel sound chip (i got 1 each).
they can install fydeos well, it’s chromeOS flex /w android support + dual boot.
fydeos is now 16.1,
i dual boot using win10 for work, fydeos for entertainment.
my win10 is bitlocker encrypted,
because fydeos is from chinese… from communist, i dont trust them.
the fydeos image is not signed nor with pgp key.
but i do use it for entertain only, and it cant steal things from bitlocker-ed drive.
