Within the page they provide you with the operating systems but it is different from what I know, since it is a .rar, and there are no instructions on how to boot it into memory
Make sure you have prepared following before you install the original Windows operating system:
write down your Windows license key, in case the system gets corrupted, using a Windows cmd instruction, so you can re-enter it manually if needed
install on usb using rufus the iso file you downloaded from the microsoft site. Don’t use the chuwi site, as it is not clean like from Microsoft
install on a second usb and unrar the file using 7-zip into a directory the drivers. Go to support.chuwi.com to download the drivers. You will need this to install the drivers after you installed windows, as there will be a lot of missing drivers
prepare a usb mouse, as during the installation and after, the trackpad will not work due to a missing driver
If you don’t understand what I mean, please google for more information.
Good luck!
Check this
Windows installation tutorial: windows installation system tutorial
This tutorial shows how to install the operating system (OS) that comes with the files: Boot
EFI
Images
Scripts
Sources
TEST_TOOL.zip
boot manager
bootmgr.efi.
BUT IT DOES NOT show how to install.
OS 2010045-V02, which has totally different files like 2101025-V00.swm
2101025-V002.swm
2101025-V003.swm
ReleaseAfter.cmd
unattended.xml
Winre.wim
