I’m using Chuwi HiPad Max. I am a subscriber to the IPTV provider IPTVBOXPRO (www.iptv.cam). It has its own Android application, but when I install it on HiPad Max and log in, the channel list does not appear. I use it smoothly on my Android phone, but I can’t use it on the HiPad Max tablet. Is there any application you can recommend to me?
You can try using IPTV Smarters Pro or TiviMate as alternatives to access your IPTV service on the HiPad Max.
Both apps offer excellent compatibility and allow you to load the channel list properly. Make sure to update the apps and check for any compatibility issues with your tablet’s Android version.
