I want to know if TPM 2.0 is available in the LarkBox Pro.
Is there a way to check it?
I rewrote the bios, but it didn’t work.
TPM is a physical device and one isn’t installed, it can’t be enabled. However, it’s not really needed for anything essential. If you want it for Windows 11, that requirement (along with the rest of the added requirements) can easily and safely be circumvented.
