I’ve read lots of posts about the thermal and fan issues. I noticed that my Larkbox runs at the ‘step up’ 2.4GHz frequency all the time - when I thought the processor should run at 1.8GHz, only stepping up to Turbo 2.4Ghz mode under load?
Other than that, I’m relatively pleased with the Larkbox - it runs Team Fortress 2 at 60fps which is impressive for such a small unit - but the thermal and fan issues do need to be addressed by Chuwi as soon as possible.
I have been using ThrottleStop 9.2 to better control the CPU frequency. While one cannot undervolt this CPU, one can be more aggressive with sliding down the CPU frequency with the power saving options.
if you set lower cpu speed, it will produce lower heat and thus it should use build in fan for cooling less, but sadly this is not possible here, bcz fan start from 54 degree, and even on idle you cant get under this temperature, so fan will not go off
