Hi All , i’m using a USB cooler instead of the fitted cooler due to the noise.
Unfortunally it stays running when i turn the pc off, anybody know wich settings to change in te Bios to take care of this ? (5 volts is always on the USB port )
Thx for any advice!
You can try to find the power management settings after entering the bios, and then turn off the option to power off the USB to solve the problem.
